tamiwalnut
#1 Posted : Thursday, January 28, 2010 1:42:29 PM(UTC)
tamiwalnut
My washer keeps giving me the FH error code which means prob w/ water flow. checked and found no restrictions. usually the water starts and stops and starts ect till the clothes are just wet enough. since this error code started the water runs continually till the error code stops the cycle again. im thinkin its the sensor. any help
sidfink43
#2 Posted : Saturday, January 30, 2010 9:49:22 AM(UTC)
sidfink43
From what you have said it sounds very much like the water pressure switch is bad, so once the machine detects too much water coming in it shuts down and displays the error message.
Check all of the wiring and connections and the tube to the switch and if everything checks out try replacing the presssure switch.
tamiwalnut
#3 Posted : Thursday, February 25, 2010 4:43:08 PM(UTC)
tamiwalnut
ordered and replaced pump switch still getting FH code (low water flow) still plenty of water coming in and it must be going out so im at a loss as to what to do now. no$ for maytag man ;D im guessin maybe its more of an electrical prob???:confused:
tamiwalnut
#4 Posted : Thursday, February 25, 2010 4:44:18 PM(UTC)
tamiwalnut
windyspirit
#5 Posted : Thursday, April 19, 2012 10:12:23 AM(UTC)
windyspirit
Check the screen behind the water hose. Unplug machine turn off water. Disconnect hose. remove screen , clean and replace.
