futbol79
#1 Posted : 17 years ago
futbol79
I just replaced ignitor - but after a full cycle at HOT it still has wet clothes. In two cycles of 70 minutes each it drys.
It starts the gas burner - but I suspect that it shuts off early.
What do I need to fix this?
glen65
#2 Posted : 17 years ago
glen65
Before getting into the dryer itself it
would be a good idea to thoroughly check the venting and
make sure the outside vent hood is fully opening.
A restriction can cause the burner to shut down before
drum comes up to the right temperature.
futbol79
#3 Posted : 17 years ago
futbol79
I have the entire path clean as a whistle
richappy
#4 Posted : 17 years ago
richappy
With damp,cold clothes in the dryer, the flame should stay on till the clothes heat up, more than 5 minutes, if not, you probably have bad gas valve coils.
