MUIRTER
#1 Posted : 17 years ago
MUIRTER
When The Button Is Pushed To Start The Drier It Sounds Like It Is Ok But The Drum Does Not Turn. You Give It A Turn Manually And Yhen It Is Fine.
bambiblaster
#2 Posted : 17 years ago
bambiblaster
The start windings in the motor are bad most likely you have a blocked vent and lint got into the dryer and choked the motor... New motor is needed and possibly the blower wheel as they are hard to get of on dryers with some age and must be cut off...
Start button turns on heater but drum does not turn (Dryer Repair)
by Guest 3 years ago
Dryer Heats, but drum does not turn (Dryer Repair)
by tzmango 6 years ago
Dryer turns on but drum does not turn (Dryer Repair)
by brandybear25 10 years ago
dryer heats but drum does not turn when turned on (Dryer Repair)
by phylli5491@gmail.com 12 years ago
Washer puts water in drum does not turn only hums and water does not drain (Washer Repair)
by vsquared 13 years ago
Dryer Drum does not turn (Dryer Repair)
by javvy 14 years ago
Drum Does Not Turn (Dryer Repair)
by Paulie K 14 years ago
Dryer Heats...but drum does not turn inside (Dryer Repair)
by nextel8 16 years ago
Motor running but drum does not turn (Dryer Repair)
by chaz24 16 years ago
Drum does not turn as free (Washer Repair)
by fjohnson 16 years ago
Dryer Drum Does Not Turn (Dryer Repair)
by Pike 17 years ago
Light comes on, timer clicks, drum does not turn. (Dryer Repair)
by bradleyque 17 years ago
