maytag/neptune not long after it starts water starts pouring out of the front door. please help
Joined: 9/10/2007(UTC) Views messages in topic : 9,586
You either have a hole in the bellows, or the gasket came loose.
Probably the control board not shutting off the fill valve, or a loose pressure switch hose.
Bill: We had the same problem - Have you checked your cold water hose filter screen? When that tiny, plastic screen gets filled with debris, the water backs up to the dispenser box, runs down that to the door and then flows to the bottom of the door making it appear as though the water is coming out the door! I put my screen at the top of the hose for ease of cleaning. Bob
