:confused:Our Whirlpool Calypso washer will give an LF code intemitantly. This only happens on the rinse cycle and it will always happen before the fabric softener is released. What could be the cause and how do I repair it.
It is possible your line through the fabric softener dispenser is partially obstructed, giving the LF error which means it is taking too long to fill. I would try cleaning out all of the dispenser lines, and if that does not fix things then you may need to replace the inlet valve assembly which may not be working correctly.
