Gordo_the_great
#1 Posted : Friday, January 15, 2010 1:59:31 PM(UTC)
Gordo_the_great
There is no water coming out of the water spout in the door. The water solenoid is good and if you disconnect the 5/16" plastic tubing at the bottom of the freeaer door, and press the water lever, the water comes out. It appears that the line in the door is frozen. Any ideas?
Migeguy
#2 Posted : Sunday, January 17, 2010 2:44:13 PM(UTC)
Migeguy
You will need a WR49X10173 water line heater for the spout coming out of the dispenser recess. Moisture has found it's way into the opening and is causing a freeze-up at the spout.
