MValley
#1 Posted : Thursday, August 16, 2007 7:36:10 PM(UTC)
MValley
Have a used Garage Sale Broan Trash Compactor. It seemed to work OK when I got it and then I tried to 'Compact' something I SHOULD NOT HAVE! :( Please don't ask me what it was but needless to say it was not soft pliable everday trash. The compactor now no longer 'compacts'. The electric motor still works and something inside is still spinning. the chain drive to the sprocket does not turn by itself except very slowly. I see something like a bearing through a hole spinning. I can put a socket on the sprocket nut and turn the compactor up and down and it seems to work OK but something has probably been busted by yours truly. I could probably tear everything apart if I wanted to but I'm not super mechanically inclined in these areas. I'm looking for a quick and cheap fix or this baby is going to the end of the driveway with a 'FREE' sign on it. Would love to keep it if I could though. :)
Admin / APP Team
#2 Posted : Friday, August 17, 2007 7:25:45 AM(UTC)
Admin / APP Team
Rank: Administration
I would check the trunnion nut first. This manual might help.
- Trunnion nut for Broan 1050
- Gearbox
Whirlpool trash compactor model TU800SPKB0 (Trash Compactor Repair)
by slcinwa 8/21/2023 10:00:12 AM(UTC)
Kitchen Aid Trash Compactor stopped- KTTS505ESS (Trash Compactor Repair)
by etiger 9/15/2020 10:13:18 AM(UTC)
How to remove JennAir trash compactor? (Trash Compactor Repair)
by snerdlybosco 12/10/2019 2:43:45 PM(UTC)
Trash compactor wont work right (Trash Compactor Repair)
by Lynnylove01 3/13/2019 7:45:54 AM(UTC)
ge Trash compactor pedal broken can't open (Trash Compactor Repair)
by tahoemark 7/25/2017 10:13:08 AM(UTC)
Trash compactor won't turn off (Trash Compactor Repair)
by fgg 8/23/2014 5:14:29 PM(UTC)
Trash compactor gears (Trash Compactor Repair)
by jfkeats 3/27/2014 1:59:16 PM(UTC)
Kenmore Trash Compactor (Trash Compactor Repair)
by verna2198 2/10/2014 4:47:46 AM(UTC)
trash compactor (Trash Compactor Repair)
by ld.rob@@yahoo.com 1/2/2014 9:51:28 AM(UTC)
broan trash compactor (Trash Compactor Repair)
by SPELLINGRA 6/17/2013 1:00:48 PM(UTC)
Trash Compactor Solid Pack does not function (Trash Compactor Repair)
by frd1952 4/3/2013 12:19:53 PM(UTC)
Whirlpool trash compactor limit switch keeps failing (Garbage Disposer Repair)
by bhorenkamp 1/10/2013 12:18:53 PM(UTC)
trash compactor motor stops (Trash Compactor Repair)
by oldschool51 1/2/2013 11:08:03 AM(UTC)
by oceanhill 10/20/2012 8:03:21 AM(UTC)
jenn-air trash compactor broken gear? (Trash Compactor Repair)
by mljdd 4/19/2012 11:02:49 AM(UTC)
