This microwave seems to function properly and it heats water great. However, after the clock timer runs out and it beeps 4 times the fans and or complete system contiues to run. The only I can stop it is to pull the plug. Am I doing something wrong?
Is there a manual?
Does it stop if you open the door?
Most likely the problem is a bad door switch assembly which is, according to the APP database, is no longer available. Here are the break down diagrams for the Litton microwave Model FS7EVPGene.
