LeahQ
#1 Posted : Monday, March 24, 2008 3:11:20 PM(UTC)
LeahQ
Hi - great site by the way....I read all the posts before I posted this so as not to repeat - but my disposal has been making such a horrid high-pitched noise, and just noticed a burnt rubber smell now, and now the water won't drain. I turned it off naturally, cleared out the un-chewed food, the water is still draining slowly - your thoughts?
Power works great, have always used water, treated garbage disposal nicely, etc....thanks for your assistance!:D
Leah
#2 Posted : Tuesday, March 25, 2008 10:33:01 AM(UTC)
Hi Leah,
The first problem is a clogged drain line which has nothing to do with the garbage disposal. You have to call a plumber to unclog it.
The high pitched noise could be because of a small hard foreign object stuck inside.
