angelinejiggetts
#1 Posted : Sunday, March 23, 2008 2:24:55 PM(UTC)
angelinejiggetts
:confused:
My Dryer won't get hot. Everything else appears to be working normal. What could be the problem?
#2 Posted : Monday, March 24, 2008 11:34:24 AM(UTC)
The first thing I would check is 240V at the power outlet.
Then you have to check the following parts for continuity:
1. The heating element (#14 on the break down diagram)
2. The thermal cut-off (#47 on the break down diagram)
3. The high limit thermostat (#48 on the break down diagram)
4. The thermistor (#42 on the break down diagram)
5. The temperature switch (#33 on the break down diagram)
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
Any of these parts with an open circuit must be replaced.
- The part number for the heating element is AP2947033
- The part number for the thermal cut-off (including the high limit thermostat) is AP3094224
- The part number for the thermistor is AP3919451
- The part number for the high limit thermostat is AP2973862
- The part number for the temperature switch is AP3037418
