The drum will not turn. When you push it start knob you can hear it try to start. I have checked the belt and there is nothing binding it. I removed the drum and bypassed the door cut-off and the motor turns fine. Put it all back together and then it won't turn again. Is there any thing I am missing? Thank you for your help.
Try turning the drum by hand in the correct direction, it should turn fairly easily. I know fairly easily is not much of a description so you may want to try this on a couple other dryers to get a feel for it.
If OK Then the probable cause is the motor not having enough power to start with a load on it. Could be that the start winding is open.
If NG Then you will have to open it up and find what is causing it to jam re; worn front glides or a bad roller etc. |
THIS FORUM IS DEAD!!!!!!! |
It is somewhat hard to turn. When you push it and start it at the same time it will start running. However it will not even push start with a load of laundry. Am I looking at replacing the motor?
Am I looking at replacing the motor? Odds are high that this is the problem.
But I would check into the drum rotation more especially if with a load in it becomes very difficult to turn. |
