Dan Young
#1 Posted : Friday, January 1, 2010 5:25:01 PM(UTC)
Dan Young
Normally when you turn the dishwasher on, you hear the drain pump start and some water sent through the garbage disposal. Now, when you start the dishwasher is seems to run, go through the cycles but you never hear it drain. When you open the door it is full of water. Pulled the dishwasher out, put power to the motor and it spins the drain pump. No problem with drain or drain line, I think it is may be a problem with a board sending power to the pump.
Thanks in advance for any help, Dan
#2 Posted : Saturday, January 2, 2010 5:11:30 AM(UTC)
Cannot find any info on the given model number.
Below is info for a PLDB999CC0
Parts
Replacement parts for FRIGIDAIRE PLDB999CC0 Frigidaire/dishwasher | AppliancePartsPros.com
Wiring Diagram
http://manuals.frigidaire.com/p...df/Kinston/154444501.pdf
Check across the pump motor with a meter to see if it is getting voltage when it should
Run the Water/Service test.
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 7/12/2021 7:43:33 AM(UTC)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Dishwasher Won't Drain or Run Cleaning Cycle (Dishwasher Repair)
by Katie L 8/4/2016 2:07:24 PM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
by brokenge 2/18/2016 2:32:59 PM(UTC)
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 12/4/2015 9:35:55 PM(UTC)
Dishwasher won't drain! (Dishwasher Repair)
by Crafter_Man 10/12/2015 4:30:35 AM(UTC)
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 1/10/2015 9:12:07 AM(UTC)
by av0612 8/6/2014 4:42:36 PM(UTC)
Frigidaire Gallery Series Dishwasher won't drain fully after disposal replacement (Dishwasher Repair)
by wicked94pgt 7/17/2014 7:31:44 PM(UTC)
GE Dishwasher won't drain (Dishwasher Repair)
by crabbygardener 6/10/2014 6:30:07 PM(UTC)
