wmichalk
#1 Posted : Tuesday, December 29, 2009 9:48:07 AM(UTC)
wmichalk
Have not used the oven in 6 months. When I turned on the oven it heated ok, but when I tried to turn it off it did not turn off. A low flame continued. What could be the problem?
Thanks for any ideas.
Wilbern Michalk
#2 Posted : Tuesday, December 29, 2009 11:39:54 AM(UTC)
Possible the gas safety valve got stuck open. Try to tap on it when it would not turn off. The model number you posted is incomplete. Verify and repost it.
Guest
#3 Posted : Wednesday, June 1, 2022 9:53:32 PM(UTC)
Guest
NhUyurng
Kenmore gas range problem (Oven Repair (including Ranges and Cooktops))
by Rob66 12/22/2019 3:38:16 AM(UTC)
Kenmore GAS Range. Model:79079013101 won't bake heat (Oven Repair (including Ranges and Cooktops))
by jfii 12/6/2019 12:56:05 PM(UTC)
Kenmore Gas Range will not stay lit more then 5 seconds (Oven Repair (including Ranges and Cooktops))
by AlexMiles 2/28/2017 5:23:58 AM(UTC)
kenmore gas range (Oven Repair (including Ranges and Cooktops))
by dennishazard 1/5/2017 8:03:49 AM(UTC)
Kenmore gas range oven won't work (Oven Repair (including Ranges and Cooktops))
by shirleyjones 12/14/2016 10:41:41 AM(UTC)
Kenmore gas range bottom burner not working (Oven Repair (including Ranges and Cooktops))
by scott mcgourley 10/29/2013 9:09:28 AM(UTC)
Kenmore Gas range hase low flame on all burners and in oven (Oven Repair (including Ranges and Cooktops))
by eddyr123 9/11/2013 12:37:23 PM(UTC)
Kenmore Gas Range PF code won't reset (Oven Repair (including Ranges and Cooktops))
by mklindsey 2/20/2012 5:40:08 PM(UTC)
Kenmore Gas Range F3/F6 error codes (Oven Repair (including Ranges and Cooktops))
by ruju 4/25/2011 9:08:22 PM(UTC)
Kenmore gas Range (Oven Repair (including Ranges and Cooktops))
by Mary Jain 3/18/2011 12:12:47 PM(UTC)
Kenmore gas range clock gains time (Oven Repair (including Ranges and Cooktops))
by bayhollow 4/7/2010 4:40:51 PM(UTC)
Kenmore gas range contol panel problem (Oven Repair (including Ranges and Cooktops))
by scba911 4/5/2010 7:51:28 AM(UTC)
Question about Kenmore Gas Range Control Panel (Oven Repair (including Ranges and Cooktops))
Belarus Xelveki 1/4/2010 9:31:21 PM(UTC)
kenmore gas range knob (Oven Repair (including Ranges and Cooktops))
by femmo 12/14/2009 5:30:28 AM(UTC)
Kenmore Gas Range bake/broiler wont work (Oven Repair (including Ranges and Cooktops))
by stillinkent 11/18/2009 12:16:30 PM(UTC)
