sandraquin
#1 Posted : Wednesday, December 23, 2009 2:42:08 PM(UTC)
sandraquin
My washer was filling then half way it stopped filling then would not run anymore. I thought it was the switch fuse so I changed it and it started working. I put in a load of laundry and it did not do anything, so I changed the fuse again and it started up again and went through a full cycle so I thought it was working so I put in a small load of laundry and it filled and stopped again. I tried again to change the fuse but this time it just wouldnt start. I dont know what to do:(
sidfink43
#2 Posted : Thursday, December 24, 2009 7:09:05 AM(UTC)
sidfink43
You need to do two things. First use a test meter to determine if the fuses are actually failing. You do this by determining if there is continuity in the fuse. Second post a full model number along with the results of testing your fuse and we will see what we can advise.
Be patient for a response, because of the holiday, and Happy Holiday Season to you.
sandraquin
#3 Posted : Monday, December 28, 2009 8:20:10 AM(UTC)
sandraquin
Be patient for a response, because of the holiday, and Happy Holiday Season to you.[/
the model # is LAT3914aam and the fuses are ok
