i`m getting a dlf [door lock fault] i took the front bottom panel off and located the lock. Can you tell me how to take the front top panel off so i can remove the lock. thanks in advance ,sjf.
the lock is replaced by removing the boot sping in front using a small screw driver and pill boot away by the switch
