kfodor
#1 Posted : Monday, December 21, 2009 7:21:34 PM(UTC)
kfodor
How do you disassemble the door to replace the handle (GE part no WB15X307) on the microwave? From the diagram it looks as if the inner trim panel Item # 1805 must be removed. Does this trim panel just snap out or is there a retainer clip which holds in place on the door frame?
From the parts breakout diagram, it looks like once this trim panel is removed the door is disassembled by removing several screws.
Is there a trick to remove the inner trim panel or any special tools required?
applianceman
#2 Posted : Saturday, December 26, 2009 9:37:32 PM(UTC)
applianceman
I believe on your model once you remove the trim you can access the screws that hold the handle on. The trim just pops off but be careful it is plastic and will break. No special tools needed. GE Spacesaver Microwave Handle Replacement
