the control locked led light is on and it wont do anything on the display. i've unplugged it for a couple of hours but didnt have any luck. what part do i need to replace. is there more than one board? help!!!
Push and hold the "End of Cycle Signal" button for 3 seconds. The controls should unlock.
that worked thanks alot! is there a reason that happens or just some weird fluke. i wondered if it was something I did
The ability to lock and/or unlock controls is a safety option to prevent non authorized use of the washer.
More likely someone wanted to turn the end of cycle signal "off" and held it depressed for 3 seconds.
