Sharon W
#1 Posted : Saturday, December 12, 2009 4:42:50 AM(UTC)
Sharon W
The indicator lights work the burners and oven do not. We have family Christmas in one week. Help:eek:
#2 Posted : Saturday, December 12, 2009 4:59:53 AM(UTC)
Could find no info on JBP30BOB1WH the following is for a LBP30BBWH1
Here are the parts
Replacement parts for General Electric JBP30BB1WH Electric range | AppliancePartsPros.com
Sounds like you have lost half the line. Lights, timer etc work off 120 volts whereas all elements require 240.
Flip your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the power at the plug.
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip, perhaps one of them has burned off.
