my oven quit heating replaced both broil and bake eleament and still have no heat
Groups: Senior Expert, Administrators You have been a member since:: 7/19/2007(UTC) Posts: 27,455
Pull it off, remove the rear cover and check the high limit switch (#23 on the body break down diagram) for continuity. Replace the high limit switch if it's open. - The part number for the high limit switch is AP3749994 Here are the break down diagrams for the Jenn Air range Model SVD48600WGene.
