I just replaced Temp Control and Relay / Capacitor . I can hear the sound compressor is running , and I touched my hand on the compressor I fell It warm. open both doors only the air blowing , not the cool air. I need help what it wrong/ problem. Thanks in advance, KBL88
Sounds like there is a problem with the sealed system. It can be low on Freon, it can be a restriction inside the system or the compressor can be bad even it's vibrating and warm on touch. The sealed system has to be tested by a certified technician because it needs a special equipments.
Originally Posted by: Gene Sounds like there is a problem with the sealed system. It can be low on Freon, it can be a restriction inside the system or the compressor can be bad even it's vibrating and warm on touch. The sealed system has to be tested by a certified technician because it needs a special equipments.
Gene. I checked total resistants ohm were good , So I will call technician come to take a test. Thanks Mr Gene
