There is another timer design used in Performa washers. Locate the hole with the timer knob shaft at the rear center of the timer. Using a small, flat blade screwdriver, pry the rod located in this hole up to release the timer knob. The knob and skirt will then pull straight off. - The part number for the timer is AP4025061Gene.
