2 Pages<12
#11 Posted : Wednesday, May 27, 2009 8:40:30 PM(UTC)
There is another timer design used in Performa washers. Locate the hole with the timer knob shaft at the rear center of the timer. Using a small, flat blade screwdriver, pry the rod located in this hole up to release the timer knob. The knob and skirt will then pull straight off.
- The part number for the timer is AP4025061
2 Pages<12
