htown_07840
#1 Posted : Wednesday, December 9, 2009 7:39:34 AM(UTC)
htown_07840
My drier wasnt giving off heat so I thought it was the heating element so I replaced it but I still have no heat. I'm not sure what I should do next. Any thoughts?
#2 Posted : Wednesday, December 9, 2009 4:32:39 PM(UTC)
Here are the parts
Replacement parts for WHIRLPOOL LEQ8857JQ0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203977704.pdf
First flip the breaker off/on a couple times slowly. Sometimes you can loose half the line without actually tripping the breaker and the heater requires the full 240 volts.
Better yet measure it at the plug.
L1 to L2 should be 240 volts
L1 ti Neutral and L2 to Neutral, both should be 120 volts.
If OK
Unplug the unit
Check that a wire has not burned off at the unit's terminal block
If OK
Check the heating element, it is not unheard of to get a bad replacement, should be around 10 ohms.
If OK
Check the operating thermostat and the hi-limit thermostats both should be 0 ohms
If OK
Check the thermal fuse this is the one on the heater, should be 0 ohms.
If it is blown also replace the hi-limit thermostat as this should have regulated the temperature so this fuse did not blow.
Only proviso on this is if the original heater was grounded, if it was then the thermostat cannot regulate the temperature and therefore blew the fuse so the hi-limit is probably OK.
If the fuse is blown check that the lint filter is not coated with fabric softener residue, check that the drum seals are OK, check that the seals in the heat path are OK, clean/check the blower wheel and clean/check the vent system.
Here is a good site with additional info
http://www.applianceaid.com/dryers.html
Guest
#3 Posted : Sunday, February 11, 2024 10:16:29 AM(UTC)
Guest
Groups:
Replaced heating element, fuse and thermostats, still no heat from the dryer? What’s the problem?
wilsonjiaho
#4 Posted : Sunday, February 11, 2024 4:58:56 PM(UTC)
wilsonjiaho
Canada
the wires were not property connect to the right terminal?
