I just fixed the leaky tub with the seal kit :) for it and now the clutch is clacking loudly:eek: :mad: . Its slipping:mad: , I thought that I tightened the tub down to tight but it still clacked when I retook everything out and ran it without the tub on it. Whats wrong?????:mad: jkl
You may have left a tool in the tub, just shine a lite in there and check.
And what if there is no tool??:confused: jkl
the washer does not spin well:( I did not over tighten the large hex nut. If I manually spin itclockwise its kinda firm but the other way its finda free.. what do you think:confused: :confused: jkl
Pull the front panel and remove the belt. Turn the tranny pulley in spin direction. If the spin basket will not turn=bad tranny.
