3kidds
#1 Posted : Tuesday, December 8, 2009 4:23:29 PM(UTC)
3kidds
My dryer won't start. It just quit working all of a sudden. The light inside is still working. When you press the start button, it sounds like it's clicking and wants to start. Anyone know where I should start?
sidfink43
#2 Posted : Friday, December 11, 2009 5:32:46 AM(UTC)
sidfink43
Unfortunately this could be one of several problems. First use a meter to check that you have 120v to each side of the connection block. Then check the start switch, and the thermostats/thermal fuses and any other thermal device in the machine.
See if the drum turns freely, if not the problem may be a broken belt which is jamming things. Finally, you will want to test the motor.
Here is a service manual which will help you out.
http://www.servicematters.com/m...ibrary/docs/16026315.pdf
sydmadcap2003@yahoo.com
#3 Posted : Saturday, June 18, 2011 11:44:19 AM(UTC)
I read every thing here I think, I change the thermo fuse but need to find more I guess
Admiral Dryer Won't Start (Dryer Repair)
by jackiebremner 11/21/2012 2:26:48 PM(UTC)
Admiral Dryer won't start (Dryer Repair)
by Woodster 4/24/2012 7:31:29 PM(UTC)
