CSAYERS
#1 Posted : 15 years ago
CSAYERS
My Washer Works Fine Accept The Agitator Will Not Move In The Wash Cycle Could It Be A Belt And How Do I Access The Unit To Find Out Or See All The Parts Inside
applianceman
#2 Posted : 15 years ago
applianceman
If it will spin but won’t agitate the first thing I would look at is the agitator coupling. Attempt to turn the agitator by hand. It shouldn’t turn easily and if it does the agitator coupling is stripped out. To replace it remove the agitator by lifting straight up. Once off you will see the coupling (it may be called an air bell on parts breakdown). A 7/16 bolt holds it on. If that doesn’t seem to be the problem post back and we will go from there. Clothes Washer Repair Guide
Removing Maytag agitator (Washer Repair)
by Guest 11 months ago
Maytag topload agitator (Washer Repair)
by Guest about a year ago
GE top load with agitator - drum is free spinning (Washer Repair)
by JLS79 about a year ago
Maytag Bravos Washer - Agitator spins fast/Drums spins slow (Washer Repair)
by JDugdale 2 years ago
oil leaking under agitator into the washing drum (Washer Repair)
by sarte 2 years ago
Beware when buying Agitator WPW1011020 (Washer Repair)
by Guest 2 years ago
Should basket spin with lower agitator? (Washer Repair)
by bdollar 2 years ago
Frigidaire Gallery Model GLWS1349AS0 Agitator Will Not Come Out (Washer Repair)
by Techowl 2 years ago
My agitator bolt will not come out (Washer Repair)
by Guest 3 years ago
GE Hydro Wave Quiet Agitator Wash System Lint Screen? (Washer Repair)
by Alphonse 3 years ago
Whirlpool agitator&spin issues (Washer Repair)
Agitator barely moves (Washer Repair)
by Xicano69 3 years ago
Grinding with working agitator. (Washer Repair)
Whirlpool washer agitator working but with grinding noise (Washer Repair)
Agitator Stuck! Can't get it out. (Washer Repair)
by TWash2 4 years ago
