TLF
#1 Posted : Saturday, March 8, 2008 7:37:15 AM(UTC)
TLF
Hello, new here, hopefully someone can give me some pointers. Wife is on my butt. Problem is when you pull the knob out to start the washer all i get is a humming noise. Could it be motor locked up or gearcase. Suppose to have it checked out this Tuesday but was hopeing to get it figured out before then and save a few $$$$$$$. $60.00 just for the trip out here.I sincerely appreciate any and all help.Also, forgot to mention,when i took the bottom off of the washer there were 2 rectangle shape black rubber pads laying in the bottom of the machine. Approx 4"x6" with one corner cut off,any ideas where they came from??
Thanks,Terry
richappy
#2 Posted : Monday, March 10, 2008 2:00:50 AM(UTC)
richappy
Pull off the outer washer cover, remove the pump and motor. Check the coupler, it might be broken.If not, you may have a bad timer. Check to see if the motor will run while disconnected from tranny. Post results.
TLF
#3 Posted : Tuesday, March 11, 2008 3:00:40 PM(UTC)
TLF
Thanks Richappy for your reply. I did take it apart and did find a broken coupler and got that fixed but now i have another problem.No matter what i set the water temp on it only uses hot water. I turned the hot water off at the faucet and then when i turn the temp knob the cold water will work but only when the knob is set in between 2 settings. If i put the knob directly on any of the normal settings i get nothing. Could that be the temp selector itself is bad or any other ideas what i need to check? I am getting voltage to both coils on the water inlet. Oh yeah, i did find where the rubber pads came from. They were glued to the inside of the washer cover, i guess to prevent the tub from rubbing during the spin cycle.I don`t know what else they would be for.
Thanks again,TLF
richappy
#4 Posted: : Wednesday, March 12, 2008 2:59:47 AM(UTC)
richappy
Check the water valve screen, it might be clogged.
Whirlpool washer locked up (Washer Repair)
by snowden207 7/15/2009 3:35:23 PM(UTC)
