winewino
#1 Posted : Saturday, November 28, 2009 9:04:19 PM(UTC)
winewino
Can't figure out what's wrong with this machine.Everything seems to be working, LED's, it fills,water heats up, counts down the cycle time, it drains. But the motor, not a peep out of it.Just replace it a bout 6 months ago and was working great til now. I read in someones post that the motor can be be jump started with just a simple spin.
Any advice on how to get it running will be greatly appreciated.
THank you
#2 Posted : Sunday, November 29, 2009 12:36:31 AM(UTC)
Pump and motor parts replacement parts for WHIRLPOOL KUDS01DLSS2 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208537797.pdf
Remove power from the unit, remove the kick plate and try turning the motor's armature using the cooling fins at the back of the motor.
If it does not turn the motor is jammed and you will have to open up the pump to find the cause.
If it does turn check the motor's windings for continuity.
If OK check to see if it is getting power when it should (120 volts)
Compressor & condenser fan not running - low voltage, start relay ok (Refrigerator & Freezer Repair)
by Guest 1/17/2024 11:51:38 AM(UTC)
Whirlpool Gold Dishwasher not running cycles properly (Dishwasher Repair)
by Joe513 6/20/2022 12:49:46 PM(UTC)
LG washer WM2050CW has water in it after not running for a day (Washer Repair)
by hklein 12/16/2021 4:48:27 PM(UTC)
RESOLVED: WR55X10942 not running after messing with diagnostic codes (Refrigerator & Freezer Repair)
by rick33 12/12/2021 12:22:21 PM(UTC)
Refrigerator Fans & Compressor not running after reassembly. (Refrigerator & Freezer Repair)
by EC Haney 10/15/2021 2:59:18 PM(UTC)
Whirlpool WRB322DMHV01 compressor and fan not running. (Refrigerator & Freezer Repair)
by Guest 4/28/2021 12:42:32 PM(UTC)
Kenmore 795.73266300 Refrigerator Evaporator fan not running (Refrigerator & Freezer Repair)
by larrywick 2/3/2020 1:27:37 PM(UTC)
Monogram ZISB420DRI compressor not running (Refrigerator & Freezer Repair)
by gunns 7/13/2019 8:38:55 AM(UTC)
Compressor and Fan not running (Refrigerator & Freezer Repair)
by TheGreek 6/2/2019 10:16:25 PM(UTC)
Kenmore elite keeps freezing up evaporater fan not running (Refrigerator & Freezer Repair)
by Joe craft 1/28/2019 11:06:51 AM(UTC)
GE Top load HE washer not running any cycles (Washer Repair)
by jonesfam0601 12/12/2018 5:39:46 AM(UTC)
Refrigerator Evaporator Fan is not Running (Refrigerator & Freezer Repair)
by lordofthering 8/31/2018 8:10:54 PM(UTC)
whirlpool sm8525079 ticking when not running (Washer Repair)
by thebrokenwhirlpool 8/24/2018 8:02:32 AM(UTC)
Samsung RS261MDBP Evaporator fan not running (Refrigerator & Freezer Repair)
by larrywick 4/9/2018 1:00:02 PM(UTC)
GE Refrigerator Compressor not running. Help! (Refrigerator & Freezer Repair)
by JohnHoward28 4/4/2018 12:12:37 PM(UTC)
