Danske
#1 Posted : Monday, November 23, 2009 4:19:41 PM(UTC)
Danske
My dryer is not heating. I had this problem a month ago and found the "high limit thermostat" PN 3390291 opened so I replaced it and fixed the problem. Today we have no heat again and "high limit thermostat is reading continuity. Thermal cutoff PN 3399848 is open, jumping the leads together on thermal cutoff I get heat. Any suggestions, should I replace both any other parts?
gabe_1981
#2 Posted : Monday, November 23, 2009 5:04:40 PM(UTC)
gabe_1981
You should replace both thermal cut-off and high limit thermostat ... They come in a kit together when you purchace the thermal cut-off ... While your in there also check your heating element to make the element its self is not grounded to any metal housing ... Also make sure your lint shute and blower wheel are clear of any obstructions to insure the thermal cut-off does not pop again.
Danske
#3 Posted : Monday, November 23, 2009 5:32:43 PM(UTC)
Danske
Thanks Gabe 1981, I will replace both. I already checked the element it is not touching housing, and not any significant lint build up. I cleaned everything very good a month ago.
gabe_1981
#4 Posted : Monday, November 23, 2009 5:40:18 PM(UTC)
gabe_1981
Sounds good ... keep me posted on your progress
Kenmore Series 80 Electric Dryer not heating (Dryer Repair)
by Steven7171 3/30/2014 5:07:52 PM(UTC)
Electric Dryer Not Heating (Dryer Repair)
by bselff 12/20/2011 12:58:18 PM(UTC)
Estate(Whirlpool) Electric Dryer not heating (Dryer Repair)
by JDB59 11/23/2011 2:05:23 PM(UTC)
by inneedofhelpplease 3/17/2011 4:03:02 PM(UTC)
Whirlpool Electric Dryer not heating (Dryer Repair)
by choover1119 3/13/2011 11:02:32 AM(UTC)
Amana electric dryer not heating up (Dryer Repair)
by Ultraman50 1/6/2011 6:58:54 PM(UTC)
Maytag electric dryer not heating up (Dryer Repair)
by jmlpa 12/7/2010 9:41:11 AM(UTC)
electric dryer not heating (Dryer Repair)
by notimetowait 10/1/2010 6:26:06 PM(UTC)
by hrose 5/19/2010 5:45:56 PM(UTC)
by 18wheeler 1/30/2010 9:16:47 AM(UTC)
Electric dryer not heating (Dryer Repair)
by phut 1/21/2010 4:30:21 PM(UTC)
by glopez01 12/7/2009 12:41:37 PM(UTC)
Electric Dryer Not Heating (Oven Repair (including Ranges and Cooktops))
by bkeiger 7/31/2009 12:27:48 PM(UTC)
electric Dryer not heating (Dryer Repair)
by RJ Trucks 7/28/2009 10:52:36 AM(UTC)
by Global Kiss 7/16/2009 10:33:02 AM(UTC)
