stein1960
#1 Posted : 15 years ago
stein1960
The washer works fine it fills and agitates with no problems
when it gets to the spin cycle it drains all the water out but the
motor does not come on and it will not spin I removed the front cover and watched it.The motor runs fine during the wash cycle
but when it gets to the spin cycle the motor does not turn on
sidfink43
#2 Posted : 15 years ago
sidfink43
Try it with the belt off and see if the problem is the motor or the transmission.
stein1960
#3 Posted : 15 years ago
stein1960
After letting it run for a few minutes the motor did kick on and it looks like the transmission is bad I found pieces of the bearing in the bottom of the washer and it will spin if i help it to turn but then it just locks up and starts to burn the belt So I guess i'll be buying a new washer after pricing the parts to fix it
sidfink43
#4 Posted : 15 years ago
sidfink43
That is what I suspected, so good luck with your new machine.
Frigidaire Washer Won't Spin after replacing drive belt (Washer Repair)
by Shindigit 12 years ago
frigidaire washer won't spin cloths dry (Washer Repair)
by MrVix 13 years ago
Frigidaire Washer won't spin (Washer Repair)
by csnow 13 years ago
by John Mascarena 13 years ago
Frigidaire washer won't spin (Washer Repair)
by maggiemc 13 years ago
Frigidaire Washer won't spin or drain (Washer Repair)
by jcutillo 14 years ago
Frigidaire washer won't spin fast (Washer Repair)
by wiredmonkey 14 years ago
Frigidaire washer won't spin won't drain (Washer Repair)
by janterry 14 years ago
frigidaire washer won't spin out!! (Washer Repair)
by highwaystar 15 years ago
Frigidaire Washer Won't Spin Out (Washer Repair)
by noley99 15 years ago
by maclean 16 years ago
Stackable Kenmore/Frigidaire washer won't spin (Washer Repair)
by sidevinder 16 years ago
by texican 16 years ago
by jwes 16 years ago
by cdiscolo 17 years ago
