Have Roper RT18HDXDW05 that makes a "clunking" noise at the end of each cycle. Is this bad? How bad? Checked all under the hood and nothing seems to be loose.
Is this a washer you are trying to fix??
Sorry...this is a refrigerator.
Is this bad? Yes
How bad? Real bad!!! Your compressor is on it's last legs. Often this is a spring that has broken in the compressor. They may run for quite a while like this as long as you can put up with the racket. Problem is you can no longer trust it and if it ends up costing you a couple hundred dollars in food, it is not worth the gamble. Turn it into a beer fridge then all you can loose in the freezer is ice cubes. |
THIS FORUM IS DEAD!!!!!!! |
Thanks...that's not the best news to hear, but I kinda thunk it already. Appreciate your directness. Guess what mom's gettin' for Christmas!!!
COOL Well hopefully freezing.
I am sure she will be thrilled, women love ice. After all a nice ice cube does look like a diamond, sorta, kinda |
