LarrySal
#1 Posted : Thursday, November 12, 2009 8:32:22 AM(UTC)
LarrySal
When I closed the door and press the control panel buttons, nothing happens. No lights, no power and no dishwashing. On two occasions when I closed the door the control panel was briefly activated, as if there was a loose connection that temporarily got nudged into place. But then the power went dead immediately afterward. I am trying to figure out how to remove the panel to check out the problem, and then I will be trying to figure out how to fix it.
