BlueWRXPride
#1 Posted : Thursday, June 20, 2024 5:24:45 PM(UTC)
BlueWRXPride
My fridge is about 10 years old, and for the past few weeks it has been making ice very slowly. The water dispenser has normal flow, and there's a pretty new filter installed. What can I check?
applianceaid1
#2 Posted : Thursday, June 20, 2024 7:26:01 PM(UTC)
applianceaid1
Canada
Was thanked: 10 time(s) in 10 post(s)
Hi,
Are the cubes normal size?
Freezer temp should be checked with a thermometer.
jeff sr.
Appliance Repair Aid
https://www.applianceaid.com/
BlueWRXPride
#3 Posted : Friday, June 21, 2024 5:13:25 AM(UTC)
BlueWRXPride
Yes the ice cubes seem normal. In this fridge the ice maker isn't in the freezer, it's a separate unit on the ceiling of the main refrigerator area.
applianceaid1
#4 Posted : Friday, June 21, 2024 5:39:42 AM(UTC)
applianceaid1
Canada
Take a reading from both.
Freezer and the ice maker room.
jeff sr.
BlueWRXPride
#5 Posted : Friday, June 21, 2024 5:43:21 AM(UTC)
BlueWRXPride
The fridge is set to 0 for the freezer and 35 for the main fridge.
I have a laser thermometer and measured the freezer around -2, the fridge at 35, and I opened the little flap in the ice maker and measured between 14 and 19 depending on where I pointed it.
applianceaid1
#6 Posted : Friday, June 21, 2024 12:10:43 PM(UTC)
applianceaid1
Canada
**I have a laser thermometer and measured the freezer around -2, the fridge at 35,**
Those seem good....but a simple pocket thermometer often works better for testing a refrigerator.....JMO!
**I opened the little flap in the ice maker and measured between 14 and 19 depending on where I pointed it.**
Not so good.
Ice maker must get below 15ºF before it will even start up.
Fan not working? Duct frozen/frosted over? Refrigerator Icebox Fan Motor should be DC14V.
jeff sr.
applianceaid1
#7 Posted : Friday, June 21, 2024 12:11:32 PM(UTC)
applianceaid1
Canada
UserPostedImage
jeff sr.
applianceaid1
#8 Posted : Friday, June 21, 2024 12:13:24 PM(UTC)
applianceaid1
Canada
#21 is the ice maker fan linked here.
This is suppose to help remove some of that nice freezer temp air and dump it into the ice maker room.
jeff sr.
