Hello all
I have a GE Refrigerator model GNE21FYKFFFS the unit without water but makes ice. The ice machine stopped working over a month ago. what I did so far.
1. Changed filter. 2. Changed Ice maker. 3. Changed GE Ref. Water Valve & Guard Assy, Part# WR57X26305 4. Un-pluged fridge blew hot air into the water hoes on all points and defrosted for 4 hours. 5. Put thermometers and frezzer temp is at -10.
No ice, can anyone assist?
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Don, the ice maker would need to be tested for 120VAC. If there is not voltage reaching it, there would be a failure in the wiring somewhere between the power supply cord and the ice maker. Unfortunately, if the failure is in the cabin liner, it would not be repairable.
