We started a load of laundry and the washer filled to what looks to be the correct amount of water. It did not appear to progress past this point.
I have tried changing the timer dial to different wash and spin settings to see if I can get any movement, drain water, or hear anything at all. I cannot.
I verified the outlet has power and it is not a tripped breaker.
I checked the lid switch and have continuity so assuming that is not the problem.
I visually inspected the wires at the motor and none appear to be loose or burnt.
Looking for any ideas what the issue might be.
