Guest
#1 Posted : Thursday, January 25, 2024 4:36:14 PM(UTC)
Guest
My washer will run a full cycle, including normal spinning, agitating, fill and draining. At the end of the cycle it will not spin the clothes dry and just ends the cycle.
Things I have done/checked
No fault codes
Pressure sensor tube is clear, and used a 1/16th bit to ensure tub side is cleared
Ran spin test in service mode, spun to full speed (manual says OOB sensor is not active during the test)
Ran an empty drain and spin cycle, did everything, drained, no spin, cycle over
I am thinking it's the OOB sensor, but that requires swapping the entire board. Really dont want to drop $200+ on that.
Any help is appreciated.
