AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Speed Queen top load washer model AWN542SP111TW01
The above model washer with s/n 1411008285 Was given to me for repair. The complaint was that it was working properly before it kicked off the circuit breaker. The customer went so far as to replace the motor and the timer assembly before I was called but it did not cure the problem. I have not checked it over yet but am requesting suggestions as to possible cause of problem. With the s/n on the data plate it does not show as being very old. It is very clean and shows no signs of abuse. If anyone can point me to a typical area or item it would be appreciated.
Washer Repair
