mashaffe
#1 Posted : Friday, January 5, 2024 9:29:35 AM(UTC)
mashaffe
My LG WM3700HWA/02 washer has started making a squeak periodically during the spin cycle. It sounds like a chicken squawking.
It's predictable and tends to happen as the spin is starting up. Tub is just starting to turn.
The only thing I can come up with is that the shocks are worn and letting the tub rub against the rubber seal at the front. Does this sound plausible?
It has the dryer on top and is in a tight spot so I'm trying to determine what parts to order before disassembly.
Here's a video of the sound. It starts at around 50 seconds in. https://share.icloud.com...eckiCr8Alnc0RhFTD2wD2k3Q
Also, I believe it has 3 shocks correct?
Thanks,
Marc
