dw85745
#1 Posted : Tuesday, October 31, 2023 3:17:11 PM(UTC)
dw85745
Cap checks fine (.95 uF +/- 3%) I read .962
Diode from Cap to ground appears OK. Shows Bad using multimeter, but my understanding need power supply to actually check since high voltage diode. (have not done yet)
Fuse OK.
Magnetron reads .14 ohm
Transformer Assume Input (from board) (.51 ohm)
Transformer Assume Output (to Magnetron) (.11 ohm)
Get 0 Ohms from CAP Wire to Transformer To Magnetron) ????
Fan and blade dusty, cleaned and appears to turn OK.
SUGGESTIONS, THANKS
Edited by user Tuesday, October 31, 2023 3:17:52 PM(UTC)  | Reason: Not specified
