I have MAYTAG mvwc565fw1, its 3 years old. It has recently started banging the sides and moving all around the room when it gets to the spin cycle. I have just replaced the springs and rods on the inside. And also, the transmission because the spline shaft had to splines on it anymore. I calibrated it and it did the self-test option. All seemed normal. It had a small wobble though. I put some clothes in it and started the washer. All hell broke loose when the washer got to the spin cycle. I had to cancel the run. It started bouncing and walking around, sounded like i was beating it with a sledgehammer. The only thing left to replace is the inner drum. I took it out and it has water still inside it. IS THAT BAD? I rolled it on the garage floor and turned it upside down. I cannot get the water to come out. It would make since it would be off balance if the water won't come out when it wants to spin.
