jcross100
#1 Posted : Sunday, August 6, 2023 11:56:11 AM(UTC)
jcross100
We have a Maytag Maxima model number: MHW9000YG0. It is 11 years old and started acting up this weekend.
1. Shows low detergent when it is not
2. Cycles hang mostly with 1 minute left.
a. Rinse/drain & spin (all spin speeds)) hangs with 18 minutes left (“spinning -
sensing”). No clothes in washer.
b. Rinse/drain & spin (without spin) cycle completed successfully. No clothes in washer.
c. Handwash cycle hung at (“spinning - sensing”) with 6 minutes left, and then at 1 minute
left. No clothes in washer.
What I have done so far:
- Cleaned pump filter
- Cleaned water inlet valves
- Cleaned all drain hoses from pump to outlet
- Removed and cleaned boot and ball from tub
- Removed and checked pressure connection for blockage
Pump seems to be working
Diagnostics produces no error codes but seems to spend a long time at test C06.
Looking for input on how to further diagnose.
