Fault Code: F6E1 Runaway Tmp on auto test. Also failures on bake and broil element.
Oven takes well over an hour to heat (only gets up to 240/260). Both elements, temp sensor, and thermal fuse all test ok for continuity. Bake elements and circuit continuity 16ohms.
No visible damage on control board but now the oven light stays on and won’t turn off… obviously thinking it’s the control board even though no visible damage.
Top elements work like normal, convection fan runs and convection element tests at 15ohms.
