Plus160
#1 Posted : Wednesday, July 5, 2023 5:05:07 PM(UTC)
Plus160
First noticed no ice in bin, replaced water filter, reset by turning off 3 minutes & ran 3 gallons thru the water dispenser in door. Replaced dual water valve internal one in top of frige, also replaced Ice level sensor in door. reset, did 3 gallon water deal, freezer is 0 degrees f, frige is 50 degrees f but set at 37, cleaned coils they were pretty dirty but not terrible. Ran full diagnostics, everything checks out OK except water filter switch & no water filter, and it says Ice Bin full but there's no cubes in the bin? ice harvest & fill test do nothing, there are frozen cubes in icemaker, heater tests ok from diagnostics. I can hear fans running & everything's workinng except ice maker & frige should be at 37 degrees f and it's at 50?
After the ice bin sensor replacement the water fill test filled the ice maker but it never harvested another message said icemaker too warm.
What do you suggest next step is?
Edited by user Wednesday, July 5, 2023 5:17:16 PM(UTC)  | Reason: Not specified
