This machine keeps kicking out with the UE error and it's getting worse and worse, I've been doing searches across the internet and just not finding an answer. I found a suggestion it could be three things, hall effect module and or stator motor so I ordered a new stator motor with hall effect sensor, that did not fix it, next was maybe the suspension rods. I ordered a new set, that did not fix it. still getting the uE code then the UE code and shuts down till I restart it. doing this with a load so yeah, open the lid and re distribute everything and start up again. I understand that's the cause sometimes but even when I set the machine up in the clean machine cycle with nothing in the tub I still get the codes over and over and it never completes the clean cycle. The last suggestion I found was maybe the main control board is causing these codes to come up. I'm kind of hesitant to order a $300 control board so I'm up for suggestions if anyone has worked through the same problems, thanks
