Hello!
I come to you all in desperation (as I'm sure most do).
I have an LG WM2455HW that I recently replaced the rotor and stator on. Or at least I tried to replace them.
Without the rotor installed, the washer drum spins freely and perfectly.
Once I install the rotor, the drum is either difficult to spin, or won't spin at all. When it does spin, it sounds like it's grinding up against the stator.
If I remove the stator and then install the rotor, it again spins freely and perfectly.
But there is little to no spin if I install the stator and rotor.
What can I do? ANY advice would be so greatly appreciated!
