AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Bosch dishwasher only drains on reset and specific cycle
Hi all,
I recently replaced the heat pump on my dishwasher, and it is working fine however after the installation now my dishwasher does not drain, it will drain if I force a reset but if I just run a regular cycle it always leaves a pool of water at the bottom. I have cleaned the filter and check the hoses everything looks fine. It really bugles the mind as I would imagine if its drain pump it would just not drain regardless but it drains completely fine if I just run a reset after the cycle. I also found that express cycle is drains fine as well but a normal cycle it would not work.
Any help would be greatly appreciated.
Thank you
Dishwasher Repair
