Hello,
I have a Frigidaire Range (LGEF3045KFK) that is having problems with the oven (cooktop is not affected). The oven will heat and is heating to the correct temperature. However, the entire oven will turn off randomly. It will often reset the clock too, and sometimes the control panel will go dark. If I hit cancel and start, the power comes right back on and the oven will continue to heat at normal temperatures. Sometimes it will shut off repeatedly in a few minutes. Other times, it will heat fine with no shut offs for an hour. I can't find if this model has a cut off or thermal switch that might be bad. Or, is the problem in the control board?
Thanks for the help.
BBBruehler
Joined: 10/1/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: IN
Hello
I have a Frigidaire Range (LGEF3045KFK) that is having problems with the oven (cooktop is not affected). The oven will heat and is heating to the correct temperature. However, the entire oven will turn off randomly. It will often reset the clock too, and sometimes the control panel will go dark. No error code is shown when this happens. If I hit cancel and start, the power comes right back on and the oven will continue to heat at normal temperatures. Sometimes it will shut off repeatedly in a few minutes. Other times, it will heat fine with no shut offs for an hour. I can't find if this model has a cut off or thermal switch that might be bad. Or, is the problem in the control board?
BBBruehler
I have the same issue on the same model. Were you able to find a solution?
