AppliancePartsPros.com
Appliance Repair Help
Washer Repair
LG LG WM2016CW Side load washing machine loud noise (clip included)
Groups: Guests
Hello Pros, Please help diagnose what this SUPER loud buzzing noise is. It happens 1. once the wash cycle is over. 2. The video shows the sound starting at the same time it starts to spin, BUT this is not the case all the time. For example, after the initial wash cycle, the water will drain, then pause, then it will make this sound without any spin or anything happening. 3. That louD “GLUGACHOOO” sound at the end is the sound coming from the drain pipe. Seems to be draining fine though. From what I could gather online, I suspected the drain pump or something to do with the drain pump. (This is all speculation as I have no idea) But it’s almost like it’s trying to engage to spin, but it’s not registering or something. Any help would be appreciated!!! Link to video with noise: https://vimeo.com/755409421Edited by user Thursday, September 29, 2022 10:29:53 PM(UTC)
| Reason: Fixed link
Groups: Guests
It doesn’t look like this forum is very active.. none of the recent previous posts have replies or answers :( sigh. Back to looking for another forum
That hum is usually a bad motor winding...R and R motor?
Groups: Guests
Originally Posted by: Randero  That hum is usually a bad motor winding...R and R motor? Hello, thanks for replying. Does r and r mean replace repair motor? I'm going to replace the drain pump motor and see what happens, ty
Washer Repair
