I have a Bosch Model 500 (SHPM65W56N/11) dishwasher which is between one and two years old. A few months ago, it suddenly would not turn on when pressing the power button. It acted as if it was receiving no power. I checked the power, and it was fine. After checking a few things, I turned off the breaker and back on again, but it didn't come back on. Based upon some hint I found online, I turned the breaker off and left it off for a while, then turned it back on. The dishwasher then worked. It worked for several months and then suddenly wouldn't turn on again. I tried the "breaker trick" but that didn't fix it. For the last week or so it will not turn on. However, during this time when it hasn't worked, it randomly and momentarily will turn on spontaneously for about 10 to 60 seconds, do something, and then shut down again and be unresponsive to the power button again. I replaced the power button and interestingly the dishwasher ran for about 10 minutes. Then it shown down again and wouldn't turn on any more. Has anyone else experienced this? I'm thinking it's probably a faulty control module. Edited by user Friday, June 10, 2022 2:33:44 AM(UTC)
| Reason: Not specified
Groups: Guests
I am having similar problem with model shpm65z55n/01. Very new machine lights come on as usual, we set machine same way as always but when I shut the door the red light light on yhefloorstarts blinking after about 5 seconds and machine does not come on. Any suggestions
