Joined: 6/3/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Alabama
I have a GE top load washer model gtwn8250dw. The water is not completely draining and clothes are still wet after a wash. I changed the drain pump and checked the drain hose for any clogs, I also removed the drain hose from the tub to make sure it was all clear. This did not fix the problem. There are no error codes when I check in service mode. I have even taken my shop vac and connected to the drain hose to attempt to remove the water but I can still hear water sloshing in the tub. Thank you in advance for any insight on what the problem may be and how to fix it.
